Error in Solidcam Postprocessor
Results 1 to 3 of 3
Thread: Error in Solidcam Postprocessor
    Jul 2014
    Default Error in Solidcam Postprocessor
    Greetings from India.
    Am trying out a CAM program for one of the component in SolidCAM 2018 trial version.
    There is one roughing (HSR) and one finishing (HSM) program for the component. The simulation does work good.
    When the GCode is generated we find that the postprocessor does have in one of the block as J0. K2 and this is creating an error on the VMC and we are unable to proceed.
    can anyone help me in this?
    Regards.
    Registered partur's Avatar
    May 2013
    United Kingdom
    Default Re: Error in Solidcam Postprocessor
    Turn off the SolidCAM and go to solidcam postprocessor path, next you need open your machine file with *.vmid extension. Then on second tab (controller definition) open section named Arc Execution Definition and check U have Arcs in ZX/YZ Plane set to NO.
    Error in Solidcam Postprocessor-2018-11-18-20_18_03-edytor-maszyny-_
    Save changes and go back to solidcam.
    Regards
    Jul 2014
    Greetings Partur,
    Appreciate the suggestion.
    We did try that and have some error. Files attached.
    Regards.Error in Solidcam Postprocessor-solidcam-error-2-jpgError in Solidcam Postprocessor-solidcam-error-jpg
    Attached Thumbnails Attached Thumbnails Error in Solidcam Postprocessor-solidcam-error-2-jpg   Error in Solidcam Postprocessor-solidcam-error-jpg
