I need help, my problem is, that my cnc control needs line (G1), arc(G2/G3) and rapid G-code in every line where it have to be, but Solidcam posts only in the first line, for example:
Re: SolidCAM line, arc, rapid G-code in every line
Gcodes are modal commands,
once set,
next line uses the prior Gcode rather than include it as redundant info..
This was implemented during the 1960's to shorten tape length.
If the control requires every line a full command ? gotta put it in
