yes the model should be the same as long as it is a format Vcarve can use.
Is there a way to import a file from solidworks to VcarvePro and have all the diminsions be the same as in solidworks?
HH
<img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
Being Disabled is OK CNC is For fuN
Try exporting an .stl from Solidworks.
UCCNC 2017 Screenset
If you are modeling in inches, the exports are probably in mm's.
No both inches.
How much are the dimensions off?
I tried to bring in a STL file but .STL wasn’t an option to open in VCP?
I’ll see if I still have the other files and how many inches it was.
Thanks Ger
HH
What version of V Carve Pro?
File > Import > Import Component/3D model
I attached the file from a Dwg format, originally it is about 60" in the X axis but when I bring it in it is roughly 5.5".
don't understand why it is reducing the size, original file was in SolidWorks.
thanks Ger
HH
Because you are exporting a drawing page. It says right on it that it's scaled 20:1.
You need to create the views in your drawing at 1:1 scale.
