Need Help! IJ mode in Mach 3
Results 1 to 5 of 5
Thread: IJ mode in Mach 3
    Oct 2010
    England
    Default IJ mode in Mach 3
    I have had a problem posting from Solidcam to Mach 3. After searching online I have found that it is a common problem and that the IJ mode is set to absolute mode instead of incremental IJ mode.
    I have put G91.1 in the G code and it sorts out the problem. Apparently I can change the mode by going to General Config in Mach 3... however I cannot find a general config in Mach 3. There doesn't seem to be anything under the config menu that will do it.
    How do I do this in Mach 3 so that I don't have to edit the Gcode everytime?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    How old is your version of Mach3? In old (really old) versions, you can find what you're looking for in Config > State.
    However, adding G91.1 to your g-code is a much better choice than just changing it in Mach3. As the IJ mode is modal, if you load any g-code that has a G90.1, it'll reset the IJ mode to absolute.
    Having G91.1 in your g-code will insure that Mach3 runs the code correctly regardless of the state of the IJ mode when you load the g-code.
    What you should do is edit your post processor to have it automatically add the G91.1.
    UCCNC 2017 Screenset
    Member neilw20's Avatar
    Jun 2007
    Gerry is right, but here is where I found it.
    On dropdown menu
    Config
    General Config
    Near center of page, Statup Modals
    IJ Mode, tick Inc.
    or in the initialization string add G91.1
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. THREE ways to fix things: The RIGHT way, the OTHER way, and maybe YOUR way, which is possibly a FASTER WRONG WAY!
    Activation process Manenitin200's Avatar
    Sep 2018
    Default Re: IJ mode in Mach 3
    cannot find a general config in Mach 3 ... SAME PROBLEM
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    hy, if you wish, i can create an app to handle automatically the IJs / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
IJ mode in Mach 3
IJ mode in Mach 3
