PWM spindle issue
Results 1 to 2 of 2
Thread: PWM spindle issue
    Member tannerc's Avatar
    Sep 2019
    Default PWM spindle issue
    I just added a second breakout board to my system to add extra outputs. I had been running on a UC100, but upgraded to ESS to get more space. The original breakout board with a built in relay and PWM output hasn't changed at all. All wires are in the same place, and I haven't touched the VFD either. All the settings have stayed the same in mach3, except I enabled PWM in the ESS plugin settings. I have double checked everything to make sure that all my pins and ports are correct. However, I can't control the speed of the spindle anymore. No matter what I do, when the spindle turns on the VFD displays 7200rpm. The voltage on the 0-10V output sits at around 9.4V. But no matter what I try, adjusting the base frequency, or motor tuning settings, or active low settings, the spindle always just turns at 7200 RPM. I haven't changed any hardware or settings on the VFD, so I feel this has to be the smoothstepper. Any ideas on how to fix this?
    Member Sterob's Avatar
    Jan 2007
    Default Re: PWM spindle issue
    Are you using a 0-10V signal or a PWM signal to change your VFD speed?
PWM spindle issue
PWM spindle issue
PWM spindle issue
