Mach3 + USS SmoothStepper + Hercus 200 Lathe = Dramas!
Hi guys anyone on here have experience with this setup? Ive had the machine for a little under a month and everything was working fine then... The spindle wont start up and the X/Y wont move or jog anymore!!! For example; I power on the Lathe, connect the USB cable, start up Mach3, Select the profile, Click the reset button, go into manual mode like usual, enter 1000 into spindle speed DRO, I can hear a relay activate, the Mach3 LED's for "spindle on" activate... buuuut nothing.. If i stop the spindle and manually rotate the chuck i get a small "Actual RPM" reading showing on the Mach3 3 screen. Im not sure where to start in diagnosing the issue?
