ESS power supply
Results 1 to 4 of 4
Thread: ESS power supply
    Mar 2012
    Default ESS power supply
    Hello all,
    I'm probably overthinking this but I want to make sure I power the ESS correctly.
    I have recently come to realize that I have been likely underpowering my ESS for some time. I recently had to replace my ESS due to some really random machine crashes and I saw visible burning/corrosion on one of the components.
    The documentation says to use a regulated supply. I'm having a hard time finding a din mountable regulated supply. I don't know a lot about power supplies so maybe I just don't know the correct verbiage to search.
    I did find a meanwell supply that has specs for line and load regulation. Does this mean it's regulated? I have attached a crop from the spec sheet.
    Sent from my Pixel 3 XL using Tapatalk
    Member mactec54's Avatar
    Jan 2005
    Default Re: ESS power supply
    Quote Originally Posted by jet8300 View Post
    Hello all,
    A cellphone power supply works fine, or a din rail mount power supply also works, you can find these on Amazon MEAN WELL MDR-20-5 AC to DC DIN-Rail Power Supply 5V 3 Amp 15W
    Mactec54
    Mar 2012
    So that meanwell supply is "regulated"?
    Jan 2005
    Most are when they come in a package like this, they have all kinds of protection built in, over voltage over current protection Etc.
    Mactec54
ESS power supply
ESS power supply
