none of the attachments are viewable. ---->
Attachment 436309
What evidence do you have that the signals got as far as the motors? -->> Can you explain better ?
What microstepping regime have you set your drivers for? ---->> I not set it, because I not understand where set this parameters.
What is your motor tuning (steps/unit)? ---->>You mean in the menù ESS pluggin set ? yes I set option Step/unit..
What units (inches or mm)? ---> I have setting in MM
Do your drivers have an enable signal and is that signal present? you mean the ENBL + and - signal on the therminals drivers ? I need of wire also them ?
Craig
