Hello
What you mean pulled? Copied?
1.This message only comes up when installing it with a License key
This is not necessary when you only want to install a trial version.
2. If you would need a license then you need to ‘assign’ it with the license manager to the particular directory.
3. When the trial version is installed, then the license manager is installed at the same time and the license is automatically copied into the correct folder
So something is definitely wrong here or you already had a version of SinuTrain on the computer.
Then it doesn’t make a difference if you choose a different partition.
You can also contact Siemens directly…
https://support.automation.siemens.com/WW/l...bjaction=csopen
