Hello,
can you provide a Machine Number?
You tell tht eye button does not help.
If this is correct I think you have a faulty Eprom?
I can check the Eproms here.
Wait for your reply
Regards
Thomas
Hello,
the red LED will be on ehen the CPU is not running,
If you press the Eye Button and switch on you will still have the alarm?
If yes, one of the Eprom Module is defect.
May this module you showed, the 2 eproms on the CPU Card or the module on the buttom
where the 3 small insertions are located.
Hello,
I only see "initializing and testing" screen no alarms
Do you have a photo?
Thank you.
Hello,
I do not have a photo,
You hav a defective Eprom module or the CPU card will be defective.
The problem is, I live in Germany
that means it is not easy to help you.
