- Installing Measuring cycles.
I have been retrofitting an older 810D system running a PCU20 towards a new PCU50.3 840D unit cuz the older one died..
Atm on 06.04.30 of the HMI Advanced software, and i got the measuring cycles package from Siemens that is supposed to fit my combination of HMI and CCU version..
Bless the retard writing these install instructions tho.. i cannot make em work ive tried everything at this point.. It is even missing files from the instructions.
Have anyone done a upgrade of measuring cycles on an older controller?? My PLC is running CCU3 06.04.13 and i got the measuring cycles 06.03.23 that according to the support "should" work.. i install em and update the GUD files and cycle the CCU and the HMI.. nothing shows up, anywhere literally..
Anybody have any good ideas?? Do i need to edit some of the .com files to make the menu options to popup or what is not adding up?!
- You may not post replies
- You may not edit your posts
Forum Rules
