Apprentice Siemens user question!
Results 1 to 4 of 4
Thread: Apprentice Siemens user question!
    Member CNCAeroDean's Avatar
    Dec 2020
    Question Apprentice Siemens user question!
    Hi guys! I am an aspiring CNC technician (apprentice). I am currently doing training in the aerospace sector and the machines we are using run Siemens 840d. During my short time so far using our milling machine I have seen the command 'SUPA' used quite frequently. What does this mean? and is it siemens or machine specific?
    Dec 2003
    Default Re: Apprentice Siemens user question!
    Not sure of the meaning but one word on the Siemens control, if the 840D is anything like the earlier versions, occasionally the hard drive would crash, in this case it is imperative to clone a copy of the HD as Siemens used to charge a grand to replace a loaded drive.
    CNCFr's Avatar
    Sep 2002
    Timbuktu
    SUPA is Siemens specific. It stands for SUPress All.
    It is non modal G-Code suppressing "all" active zero offsets or more accurately all frames for one block-
    I wrote "all" in quotes because you may define the exact behaviour with machine data (for example you can define whether the offset of the currently active tool is to be ignored or not).
    SUPA is most often used when moving to the point for doing a tool change.
    Dec 2020
    Thankyou!
    Oct 2010
    Here's a snapshot in the HELP of the conrol.
    Apprentice Siemens user question!-supa-jpg
