Sinumerik 810 Bar puller
Results 1 to 2 of 2
Thread: Sinumerik 810 Bar puller
    Member Vladimir995's Avatar
    Sep 2020
    Default Sinumerik 810 Bar puller
    Hello, it's been a while since I'm trying to solve some problems on the new toy in our machine shop.
    Recently we purchased DMG CTX 310 (2005) with Sinumerik 810 powerline control unit. I have expirience with HAAS and Fanuc control units but Siemens is whole new for me.
    I'm trying to make it cut part from bar and than to pull bar from spindle whit bar puller. I've been doing this on our HAAS and John Ford (Fanuc) lathes but I can't figure it out on Siemens.
    I found somewhere that command for Spindle unclamping is M13, so I've been trying to check it out but it won't even unclamp when I put this command in some program that worked before.It says that the command is admissible.
    Can anyone give me some instructions how g code should look (so I can try writing whole new g code without cam) or what is the problem that doesn't let me unclamp spindle in the program?
    Registered Jwwbreaker's Avatar
    Feb 2009
    Default Re: Sinumerik 810 Bar puller
    Try M11
