Hello everybody!
I,m new using this plataform to be in touch with colleagues about CNC programing and I hope does anybody can help me.
I will machining one drill and and thread (M8 X 1.25) using an angle head 90° with a tap, the hole is in G19 reference plane XY, thread axis is paralel to X axis of the machine, is the first time that I need to machining a hole that is not perpendicular to Z axis.
My doubt is:
If I program G19 before the CYCLE84 then all the parameters for the cycle will be reference to that plane (G19 YZ)? for example for the parameter "DP" final Depth the machine will move in X axis because I selected G19? works like this? if not how I have to program it?
