- Need Help!- Serial port via NC program
Hello everybody!!
We have CNC center with Sinumerik 840C I want to add a measuring instrument to machine.
The instrument has a serial RS232 Output , is it possible to read serial port while NC program is running? for example use @ ..... I want to read the measuring data and save it in R parameter or..
then I can correct the program.
- You may not post replies
- You may not edit your posts
Forum Rules
