- Problem- technical support
technical support
good day to all
I have a small problem with my servo bar 300 of haas, some time ago they changed an electronic card due to problems of operation in my lathe sl 10 and I had not required my feeder of bars; the problem is that today I tried to activate it according to the manual when makes the ride the pusher makes a noise like a mechanical snap and I do not know if was for changed of card of since it used to work correctly if someone that has an idea that can help me resolve this I thank you in advance (help me).
- You may not post replies
- You may not edit your posts
Forum Rules
