- Need Help!- Hole pattern using C-axis on the lathe?
Hi. I'm trying to create a circular Hole pattern with the holes2 cycle. This works as Long as the diameter is less than 100mm due to limited Y travel. So I need to use the C-axis somehow, but I don't see that option in holes2. Am I missing something or is there a different cycle I need to use? The controller is Sinumerik 828D. Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
