- Newbie- Gcode - set axis offset function
*Registered User*
Hi everyone,
I'm working with SINUMERIK 808D control for sharpening machine,
when I clean the stone I have to re-offset the Z axis.
I want to know if there is a G function that let me set a new offset inside the gcode?
thank alot.
Gadi
*Registered User*
Re: Gcode - set axis offset function
Hi guys.
I found something that can help me with this operation, may be helpful for someone.
https://www.cnccookbook.com/g10-g-co...achining-haas/
still don't understand the function parameters:
G291
G91 G10 L_ H_ P_ R_
G290
what L, H, P, R means?
- You may not post replies
- You may not edit your posts
Forum Rules
