- Output coding
Output coding
Can someone please answer a simple question, here is some code;
N0000 DEF STRING[32] _FILEPATH = "/_N_WKS_DIR/_N_RESULTS_WPD/_N_"
This is taken from a probing program, clearly the filepath to save the data to is Results.......
However we have 2 different drives it seems on the controller, is there a way to see the file structure? My PC can only access a folder called \\10.231.73.xx\TRANSFER.dir and would like the file outputted there.
Kind regards
- Output coding
- You may not post replies
- You may not edit your posts
Forum Rules
