- error EMCO 325
Re: error EMCO 325
WinNC is not Siemens so probably won't find help here. You must have an older Emco AC95 control and a 325-II? Essentially AC95 is not supported any more and they want you to upgrade to the Concept control. If you have installation discs for WinNC, you could probably reinstall, but it's odd that you have anything missing in the first place. Did you clone or make any changes to the HDD?
- error EMCO 325
- You may not post replies
- You may not edit your posts
Forum Rules
