Hi, to switch to inch, in jog mode or auto mode, click the little arrow on the lower right corner, it's just above the "Machining" horizontal softkey (if your in jog mode),
then on the "Setting" softkey, then on "Changeover inch" on the Vertical key.
And WPD is for a WorkPiece Directory that you create., the MPF is the part program.
