Sinumerik 828D. SNCK not initialized for simulation.
Results 1 to 4 of 4
Thread: Sinumerik 828D. SNCK not initialized for simulation.
    Jan 2018
    United Kingdom
    Default Sinumerik 828D. SNCK not initialized for simulation.
    Hi everyone.
    I have problem with initializing simulation. It's started after I tried to create new subprogram. Unfortunately I picked wrong name for it, which started from 2 digits - 30DEG.SPF. At the moment file no longer exist in NC data->Cycles->User cycles folder, however systems stills see that file (I think).
    I'm getting following errors and I can't run simulation:
    12080 - Channel 1: Block N1 syntax error in text
    15175 - Channel 1: Block program _N_30DEG_SPF. Interfaces could not be build
    Thanks for any help.
    Member IsakAndersson's Avatar
    Oct 2018
    Default Re: Sinumerik 828D. SNCK not initialized for simulation.
    I have the same problem. Started after I added a subprogram to the custom cycles folder. No clue how its related, but I guess it must be somehow. Anyone got a clue?
    Jan 2018
    United Kingdom
    I solved this by reseting simulation. [Menu select]->[HMI]->(>> - more options)->[Reset simulation].
    Oct 2018
    Thank you! This fixed everything. Still not sure what went wrong in the first place. Not going to complain though. Thanks again!
