Need Help! Siemens CNC 810D Tool Turret Problem
Results 1 to 2 of 2
Thread: Siemens CNC 810D Tool Turret Problem
    Apr 2013
    Dhaka, Bangladesh, Bangladesh
    Default Siemens CNC 810D Tool Turret Problem
    Dear Boss,
    We have CNC lathe machine. Recently we have change the gear and Turret.
    After that if I click Cycle Start, machine show the following Alarms:
    700312: Active tool not valid any more
    25040: Axis Turrn Standstill Monitoring
    If I enter CNC ISO mode: Then Turret show: 5.9644 degree.
    But tool is in Position 1 , So, it should display zero.
    Can you please suggest me the solution for the problems.
    Mar 2016
    Poland
    Default Re: Siemens CNC 810D Tool Turret Problem
    You need to calibrate turret.
    It should be described in service manual. As i remember You need to press hydraulic start button and while keeping it move the turret 4 full turns by manual, but it may vary depending on machine.
