hi ,
type the letter /numer in youre case L and then delete (one of the buttons next to the yello).
then the next letter D and delete .
must solve the problem ;-)
greetings bertus
Dear Friends.
I have a 1996 emco 425 with sinumerik 810T.
A "friend" inserted in MDI mode a lot of letters and numbers with no sense and i can`t delete them... i attached a photo ...
how can i delete this in MDI ?? any ideas?
Thank you!!!!
hi ,
greetings bertus
Hi guys, i’ve a little problem with 810t Siemens, it’s impossible to delete a single block or N letter or close block simbol. On MDI and also in the automatic program
can you help me?
other letters like G or M or X or other it’s possible delete.
Thank you
Paolo from Italy
If all that is on there is the "LF" character, then push the green cycle start button in MDI. They'll go away.
