Ya smoked the memory/Cpu.
Hello everyone,
Sorry if this is in the wrong forum, but I'm in need of help figuring out what some error codes mean
I've looked at the operation and programming manual (http://support.automation.siemens.co...edownload=true) but it isn't exactly enlightening. What it says is that alarm 8, 13 and 1080 only happen on commissioning, alarm 3 needs a service technician and alarm 2000 is the only one with meaningful information:
Reason:
The EMERGENCY STOP signal is output from the PLC to the NC
Effect:
Inhibiting of NC START
– Operation is brought to a defined stop
– Servo enable is removed
– Follow up operation
Remedy:
Check to see if the EMERGENCY STOP cam was traversed to, or if
the EMERGENCY STOP switch was operated"
Alarm 2000 should be a simple fix I think. Just checking all the switches on each axis plus maybe a few others.
The original cause of the problems is that the machine got connected to 440V and it's only rated for 220V.
Any suggestions.
Thanks,
Sounds like it could be expensive.
It's a good thing I have committed to buying the machine.
Anyway to tell if it's the memory or CPU or is it pretty much guaranteed that they are both fried? Do you think that replacing those would fix the other alarms?
Well, PLC stop and Emergency stop would make sense if the CPU and memory is gone. Problem is, you really cant test drives and such until you get that fixed. Maybe a lot more damage than meets the eye. You probably need someone more familiar with Seimens, those arn't popular in the US.
Each thing will need to be checked through.You have a screen up so can`t be fatal.
You need someone capable to go through it.The drives can be tested independently with a battery box which is standard procedure for commissioning the machine anyway.
Probably Siemens 6SC610 drives on that machine.
I`ve got a Chiron FZ12S with 810 control.They are quite simple machines.
I just heard back from Chirons Siemens tech and he's saying that the machine just needs the original parameters and settings loaded. I'll be testing the drives later this week hopefully.
I need Chiron Fz12 NC Parameter an PLC program.
Thanks.
Hi friend Alicnc,
Are you having the chiron machine NC and PLC backup.
Last week machine parameter lost due to battery problem.
CHIRON FZ12W MAGNUM HIGH SPEED
SINUMERIK 810M GRAUNDAUSF3
MANUFACTURE YEAR 1997
Regards,
Dhina
hi folks
i have fz12w 810m ga3 chiron because of dead battery i lost all parameters i found tea1 tea2 but i need pcp file if anyone can help ill be appricated
thanks all.
Hi, do you have parameters for Chiron FZ12W High speed 1996 Siemens 810m GA3? Thank you
I have same problem.. need parameters for Chiron FZ12W.
mlisica55@gmail.com phone +38766284310
