- Feed power
Feed power
Hello
Milling Siemens 840D
What was the command to limit feed power
example:
S444 M3
G01 X777. F1234
???=80 ; max power 80% (normal 100%)
the feed/power will lower automatically now
Re: Feed power
G96 S... LIMS=... F... ;Constant cutting speed ON
G97 ;Constant cutting speed OFF
S ;Cutting rate, m/min
LIMS= ;Upper limit speed of the spindle with G96, G97 effective
F ;Feedrate in mm/rev(G95); in/rev (G94)
- Feed power
- You may not post replies
- You may not edit your posts
Forum Rules
