interpolation turn on a 840C
Results 1 to 3 of 3
Thread: interpolation turn on a 840C
    Registered jim5062's Avatar
    Mar 2006
    Zafra / Spanien
    Hello,
    interpolation turning on a 840 D is no problem- but what about doing it on a 830 C?
    Does anybody know about it?
    Jim5062
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Hello,
    If you mean the circular interpolation then there is no difference!
    Give us a bit more information so we can help you.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    nbh's Avatar
    Jul 2003
    Bad Mergentheim
    Hello,
    Well I believe its works: switch spindle to axle operation and go ….
    With the 840 D the turn is an easy thing, on the C it’s a lot more effort to program it.
    It’s best to program it over a repetition loop, then you can change settings easier.
    Unfortunately we don’t have a 840 C anymore, otherwise I could have helped you.
    Greetings Werner
