- File transfer problems, need help
When sending a file to my "new" lathe it errors every time. I get the
first 500 bytes of the file then it quits and gives errors 110049 and
110058. " check interface parameterization" and "transfer aborted"
I tried used Bobcad V21 and AGGsoft DNC Precision, both give the same
results. I tried with software Xon/Xoff and Hardware RTS/CTS with the correct cables.
The part of the file that does go through looks fine and will run.
any suggestions?
Hyundai HIT-18S
Siemens 840C
- You may not post replies
- You may not edit your posts
Forum Rules
