- Siemens sinumerik 810m ga2 DNC
Good day!
Is DNC mode possible with 810M GA2?
Thank you!
Re: Siemens sinumerik 810m ga2 DNC
Yes go into Data In/Out and select data in and data out from there. You will need to set your communications in the 5000 setting parameters
I only have an input and output option. I don't have a BTR(GA3) start option
- You may not post replies
- You may not edit your posts
Forum Rules
