- HELP Siemens 840D
HELP Siemens 840D
Hi.
I have an DMU 50 with Siemens 840D.
I have some troubles with programming Cycle977. Cycle 977 is Hole measuring with renishaw probe. I want to program the cycle with toleransing and compensate on tool wear.
Is there anyone who can make an example or explain what should be in the various boxes under tolerancing? Maybe you could send a picture?
I think i have tried everything, and i always get alarm 61304 Allowance. Maybe someone could explain this alarm for me?
The manual has been read out several times already.
When i get Cycle 977 working, the goal is to jump back in the program to remachine the hole if it is out of tolerancing.
- HELP Siemens 840D
- You may not post replies
- You may not edit your posts
Forum Rules
