R value question
Results 1 to 2 of 2
Thread: R value question
    Nemoid's Avatar
    Dec 2021
    Default R value question
    Is there away to sequentially update r values in a loop?
    What I have is a long series of r values that I wish to use as positioning data but instead of writing all the individual r values in a program I wanted to create a loop as below but each time the loop runs the next r value in the sequence is loaded so:
    R1-R40 all have data
    R100=40; used to count
    Loop:
    R100=R100-1
    A command here to move R1 to R2 etc
    G1 x=r1 f500
    If R100 > 0 gotob loop
    Hope this makes sense
    Member DMU_200FD_KEITH's Avatar
    Dec 2021
    I think this may help you.
    You can specify R values with an equation in that line
    Like R1=R1+1 or minus as well.
R value question
R value question
