maximum feed rate - sinumerik 840D control
Results 1 to 1 of 1
Thread: maximum feed rate - sinumerik 840D control
    Aug 2010
    canada
    Default maximum feed rate - sinumerik 840D control
    is there a parameter i can change to set the maximum feed rate accepted by the control?
    need to cut a thread with a 6" lead......
    thanks in advance.
    CNCFr's Avatar
    Sep 2002
    Timbuktu
    Default Re: maximum feed rate - sinumerik 840D control
    I don't think that you can increase the max. feed rate of your machine by just changing a machine parameter. That rather would require more powerfull drives.
    Why do you think that the max velocity of your machine has been reduced unnecessarily during initial setting up?
