Need help with Sinumerik subprogram
Results 1 to 4 of 4
Thread: Need help with Sinumerik subprogram
    Member 12345abc's Avatar
    Feb 2019
    Default Need help with Sinumerik subprogram
    I am trying to program a loop for broaching a keyway. I am making subprogram for that, but dont know how to program it correctly so I need some help.
    I am trying to program this:
    G0 Y-5 (comming to starting position)
    G1 Z-72 F3000 (broaching down with a feedrate)
    G0 Y0 (rapid to safe y position)
    G0 Z1 (rapid out to safe z)
    G0 Y-5.05 (rapid to next y position)
    G1 Z-72 F3000
    G0 Y0
    G0 Z1
    G0 Y-5.1
    So the question is how to write a cycle that goes to to the next y by he same amount (y-5.05 ; y-5.1 ; y-5.15; y-5.2 etc) for lets say 60 times. Of course I can write that manually, but maybe it is possible to write a cycle for that?
    Hope you understand the question.
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Need help with Sinumerik subprogram
    ... use an Incremental move with Y say .1mm looped 10 times would be 1.0mm or what ever you like
    Feb 2019
    Can you write an example how the code with incremental move should look like?
    Aug 2009
    ,,,here's one way might work for ya....format might not be correct...change as needed
    in the Main program Position your start point
    N100 G0 G90 X0 Y-5 Z1 (starting position) or what ever
    N101 BROACH Pxxxx (the P is how many times to repeat the sub program)
    N102 G0 G90
    N103 G28 Z0
    N104M30
    BROACH
    G91 Y-.05
    G1 Z-73 F3000 (broaching down with a feedrate)
    G0 Y.05(rapid to safe y position)
    G0 Z73 (rapid out to safe z)
    G0 Y-.05 (rapid return from safe y move)
    M17 or M99 (not sure for your machine)
    Attached Files Attached Files
