- 810D is my backup good?
Re: 810D is my backup good?
Hi H90,
You will need to open your back panel and see what display is shown on the CCU card. The CCU card has a seven segment LED display and about 8-10 LED lights below that.
The waiting for NCK connection error basically occurs where there is something wrong on your CCU card side. If you're lucky, its just a software issue.
The software backup being referred to is saved as an ARC file and normally saved in your PCU20 if i'm not mistaken.
The process for reloading the backup is well documented on the siemens forum- you should check over there.
Best of luck!
- You may not post replies
- You may not edit your posts
Forum Rules
