NOT CORRECT VALUE OF AXIS C
Results 1 to 2 of 2
Thread: NOT CORRECT VALUE OF AXIS C
    Registered asalliou's Avatar
    May 2012
    pau
    I will have to set up a turn & mill lathe equipped with a sinumerik 840Dsl N.C. and I encounter an alarm "not correct value of axis C"... For a 5 continuous axis milling (RTCP mode), an alarm appears when I try to move to C4=-100 for example. If I change the C4 to a positive value, it works!!
    Is it a parameter to set up? or a programming code to add??
    Thanks in advance for your support,
    Anthony
    Jan 2013
    Swe
    Default Re: NOT CORRECT VALUE OF AXIS C
    Think I might have a similar problem.
    Have you solved this issue? If not, I hope someone can assist with help. Thanks.
