R-parameter
Results 1 to 4 of 4
Thread: R-parameter
    Registered tuerk's Avatar
    Jan 2010
    Oberlungwitz
    Hello everybody
    Could anybody help me? What parameter does 810d use for saving of milling radius. I need its calculation for cycle writing.
    Greetings
    Ct
    mori4200's Avatar
    Jun 2008
    Warren,PA
    Hello
    $P_TOOLR is the one you need.
    The whole radius of the milling cutter incl. wear stands in R1 with R1=$P_TOOLR.
    Mfg MORI<br /><br /><br /><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto--><b><u>“Armselig der Schüler, der seinen Meister nicht übertrifft“</u></b><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc-->
    Jan 2010
    Oberlungwitz
    Thanks for the rapid help!
    jR0's Avatar
    Jan 2024
    Default Re: R-parameter
    Hello together,
    is there a Parameter, which i can use to query the tool radius of any tool in my toolmanagement/toolstorage/offsetdata?
    I know that i can use the $P_TOOLR Parameter to query the radius of the actual tool in the spindle, but i need to write a funktion in the program - header, which has to compare the tool radii of all following tools with given tolerances.
    Does sbd. have such experiences?
    Greetings
    Jakob
R-parameter
R-parameter
