- M3/M4 not possible, chuck isn’t closed
Hello
The named above error occurs at my machine when I try to execute programs with a tailstock.
After the point of tool change is reached, the program stops.
The chuck works properly without tailstock.
Machine: CTX 310.
Software: Shop Turn 06.03
Who could help me?
Hello
I believe the reason is the sensor that informs about the deployed sleeve or wrong settings (not enough locking pressure of hydraulics).
Set the hydraulic pressure higher, maybe it’ll help.
Greetings
- You may not post replies
- You may not edit your posts
Forum Rules
