delete data rubbish
Results 1 to 4 of 4
Thread: delete data rubbish
    Rahmspinat's Avatar
    Oct 2002
    Neuwied
    Good morning
    On our Shopmill we have several programs that are stated with size 0.
    Recently an INI-file with size 0 always gets produced when programming multiple set-ups.
    Does anybody know how to delete this rubbish?
    Regards
    Caddy
    hapo
    Guest
    First of all you should check if the files are really empty ( in the program manager: cursor onto data INPUT)
    If the editor is empty, then you can delete the files.
    In order to do so, activate the soft key extension over the program manager ">" and select the soft key “delete file” in the right soft key bar.
    Then you can press the soft key “OK”
    Rahmspinat's Avatar
    Oct 2002
    Neuwied
    Hello
    If that would be that easy then I would not post this question here.
    Regards Caddy
    hapo
    Guest
    Ok I forgot to mention that a file that was loaded in the editor cannot be deleted.
    So first close the editor or open another file in the editor.
    If is still doesn’t work:
    - Enter a few signs in the file that’s open in the editor and save it.
    - Close editor or open other file in the editor.
    - Select the file in the program manager and press the soft key „delete file“
    - Delete security query with the soft key “OK”
    With some software versions of the Sinumerik 810D/840D with hard disk (PCU50 or MMC103) it might be possible to first off load and unlock the file before deleting it.
delete data rubbish
delete data rubbish
delete data rubbish
