Hello
Usually back with double feed compared to the one you pull in.
Hi
I’d like to know what retraction feed motion you use during rubbing.
I work with 840ds.
Please with material, bore diameter and speed. It’s just for comparing.
Thanks in advance
Hello
So I move with 2mm per rotation out?!
I.e. S=1000 U/min F=2000 mm/min
Rubbing doesn't deal with controller! Technology is always the same!
Important is what surface I need (Ra/Rz) and cutting material.
HSS
Hard metal charged
Hard metal
PCD
Which do you have for which purpose?
Regards
Boern
<b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
