Problem Problem with SIMODRIVE 611 U/E module
Results 1 to 1 of 1
Thread: Problem with SIMODRIVE 611 U/E module
    Member stipe991's Avatar
    Jun 2019
    Default Problem with SIMODRIVE 611 U/E module
    Hello everyone,
    We have a problem with the U/E module on a 4-axis CNC machine consisting of the following hardware configuration:
    - Siemens 6FC5210-0DF22-2AA0 Sinumerik PCU 1.2GHz, 256RAM
    - Siemens 6SN1146-1AB00-0BA1 Simodrive U/E module int-ext.5/10KW (VERSION A)
    - Siemens 6FC5447-0AA00-0AA1 LT-MODUL
    - Siemens 6FC5410-0AY03-1AA0 Sinumerik 810D CCU3.4 software vers. 6.5
    From the pictures in the attachment, you can see that the red 3rd LED is lit, and in the manual I found that it indicates that there is a problem with the power supply.
    I checked the voltage at the input and it is 407V, while the voltage on the DC bus is around 590V (after I give permission from the auxiliary circuit).
    Thanks in advance!
    Attached Thumbnails Attached Thumbnails Problem with SIMODRIVE 611 U/E module-img-6348-jpg   Problem with SIMODRIVE 611 U/E module-img-6350-jpg   Problem with SIMODRIVE 611 U/E module-img-6347-jpg
