- Fusion and an 808D
Fusion and an 808D
I’m new to CNCing. I have a 2 axis lathe with an 808D controller. I have had a couple of days training and the guy who trained me is giving phone and email support but I’m struggling with the ‘repeat’ command.
I’m using Fusion and I’m making parts, that all working great. I find the Fusion posts need some editing in particular the tool change position needs to be further away from the chuck and some of the feed rates are missing. Could this be a post processor problem?
I’m getting caught up on the commands that repeat particular parts of the program. For example I want to machine the OD to Z-27mm and then part off 5/6 times before resetting the stock to Z0. What are the commands for repeating the parting off section of the program?
- You may not post replies
- You may not edit your posts
Forum Rules
