Change zeropoint manually
Results 1 to 2 of 2
Thread: Change zeropoint manually
    Junior Member hans89's Avatar
    Jul 2016
    Default Change zeropoint manually
    I work now on a new special machine and I try to chane the zeropoint during the program. For this I press cyvle stop, change for example g54 x +50 and then I press again cycle start. On other machines the machine drives then in X + 50 (like repos) and continue the program. On this machine not. It ignore the zeropoint change completely. If I use the overstore it also doesn't work:
    Overstore g54 cycle start...
    Does anybody know what the mistake is, or has some ideas?
    Br
    Hans
    Gesendet von meinem SM-N910F mit Tapatalk
    Jul 2016
    The control is a siemens 840d sl
