system 3 enter programs
Results 1 to 2 of 2
Thread: system 3 enter programs
    Registered Mazemukel's Avatar
    Oct 2007
    Schaafheim
    Hi
    I have the following problem with my Siemens control system 3. Until recently it ran without problems, it was one of the cards that suddenly shows a periphery fault and I could not approach all points in programs anymore. Then we have drawn out the Ram card and entered the machine data again.
    If I now select the MDI function, where I can usually enter the programs, then the programs always crashes and it only shows me the message, MDI program:
    L ????????!
    Does anyone know what I need to do to make this work again?
    greetings
    Mazemukel
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Hello
    How exactly can I understand the term "Enter"? Do you want to write a new program or edit an existing one ?
    Do you get the message MDI program: L ????????!, right after you went to Open up?
    Then it could be that the program no longer exists in the memory.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
