- program Sprint65 840D SL
Hello everybody
Has anybody experience with the programming of Sprint65 or Sprint 90 with Siemens 840D SL?
What is programmed at MS1 spindle does that also run on FS2 spindle?
Or do I have to reflect it or change it somehow??
Thanks a lot
Regards GITAL
Many roads lead to Rome...
In Shopturn usually the zero point for the opposed spindle with reflected Z axis is used and the opposed spindle is turned into the master spindle.
Like that, the program for the main spindle is now executable on the opposed spindle.
Of course the tools need to be created and set up accordingly...
- You may not post replies
- You may not edit your posts
Forum Rules
