- Back turning cycle
Back turning cycle
Hi
I'm trying to make a subprogram which allows back turning for any contour.
So far, I made a simple subprogram with parameter transfer that allows turning a shaft from one diameter to another.
I have a problem when I'm trying to create subprogram for any contour. I would like that subprogram would work just like, for example CYCLE95 (create contour whit G-codes and after that turning according to this contour).
I tryied to use CONTPRON instruction, but I'm not sure how to do this.
Is that possible at all, to prepare this kind of subprogram ?
I need to some advises. It's very importent for me.
I use SinuTrain 4.5, because I don't have access to real CNC machines.
Best regards
- You may not post replies
- You may not edit your posts
Forum Rules
