- problem choosing level 810d
Hello
I have the following problem:
I have to add Mill slots into a round part.
However I have problems with the shift of the layers.
I absolutely can't remember how I do that again.
The turned part is ready so far, just the mill slots are missing.
I also want to know how I can achieve that the spindle always starts at for example 20°.
Many thanks for your hints.
Hey Masi
It should work G17. Then it’s the milling layer.
About your second question: After the turning – spindle stop with M5. Afterwards Spos1=0 and then Spos1=20. You have to add a squared bracket around the 1!
Regards Michael
- You may not post replies
- You may not edit your posts
Forum Rules
