What do you mean? Automatically with a cycle or a manual start off with the sensor and NP shift in C?
Hello
I want to start off with a measuring sensor on a component part that is onto a wave ( with a turning machine and 840d controller) and then give the highest point to the controller as a spindle position 0 degree.
Can anybody help me out?
Thank you!
Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
Is it a kind of switch cam that you want to adjust?
With such a measurement, the geometry of the curve is quite important.
Maybe you can post a sketch...
What kind of sensing device should I use? A switching sensing device or a measuring probe with an own metering shaft???
