- Measuring system 1 and 2
Hello
Could anybody explain the difference between the both measuring systems mentioned in the topic head?
Thanks in advance and kind regards, Hans
The 840D can work with the both systems. The system 1 is normally the motor measuring system, the measuring system 2 is the glass scale. So if the glass scale fails, at a pinch, it’s possible to go on working with the motor measuring system.
Greetings
Michael
- You may not post replies
- You may not edit your posts
Forum Rules
