- Problem with init
Problem with init
How to load a program into memory NC MDA mode?
I know it serves the function INIT
Assuming the program that you want to select is in the WCS in the "A" and a program called "A.MPF"
I type in MDA line:
code:
INIT (1, "_ N_WKS / _N_A_WPD / _N_A_MPF")
M2
and crashes my alarm 15010 -command coordination with the incorrect channel number: ???:: ???:
The channel is one syntax of the book and I can not go around trying someone in this way, load the program into the NC?
Sorry for my language ;/ I use google translator
- Problem with init
- You may not post replies
- You may not edit your posts
Forum Rules
