error messages
Results 1 to 4 of 4
Thread: error messages
    Registered ANI-MAT's Avatar
    Nov 2011
    Karlsruhe
    Hello everyone
    From the PP run get the following error messages. Can anybody tell me what I am doing wrong? Machine is a DMU 50eco Siemens 840D.
    KANAL 1 block N27 orientation transformation not available -----------------------------------
    program extract
    N14 ROT
    N15 TRAFOOF
    N18 T20
    N19 M6
    N20 S2000 M3
    N22 R98 = 300 ; IMMERSION FEED
    N23 R99 = 1000 ; MILLING FEED
    N24 CYCLE832(0.03,3)
    N25 TRANS
    N26 G0 B0 C=DC(0)
    N27 TRAORI
    N28 G54 D1
    N29 AROT X0 Y0 Z0
    and these messages:
    KANAL 1 block N20324 same G-group program several times
    program extract
    N20323 M9
    N20324 SUPA G0 G53 D0 Z0
    N20325 SUPA G0 G53 D0 X0 Y0 (G53 twice ???)
    N20326 TRAFOOF
    N20327 G0 B45 C=DC(270)
    N20328 TRANS
    N20329 ROT
    N20330 TRAORI
    N20331 G54 D1
    N20332 TRANS X0 Y-20 Z0
    N20333 AROT X45 Y0 Z0
    N20334 X34 Y-23.971
    Thank you a lot
    Have a nice Easter time!!
    Matthias
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Hello as far as I know it should look like this:
    N26 TRAORI
    N27 G0 B0 C=DC(0)
    In the second case I would say - G53 and SUPA are identical, that’s why the multiple programming occurred.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    woaldy's Avatar
    May 2006
    Elmshorn
    Hello ANI-MAT
    /G53 twice???)
    G53 and SUPA are not modal as far as I know, that why the command has to be in every single row.
    Regards woaldy
    hapo
    Guest
    N27 TRAORI
    TRAORI is not unlocked-it seems like the license is missing
    KANAL 1 block N20324 same G-group programmed several times
    SUPA and G54 affect the individual block and have a similar affect. G53 suppress all transformation in the programmed block above G500.
    SUPA reduces all transformations in the programmed block to the MKS (also G500 is suppressed)
    Hence both command are not allowed to be used together.
    As you have the error number you can have a read in the Diagnostic Manual.
error messages
error messages
